hard starting i think it's fixed
I don't get it
Lift pump-cause?
Have been having problems with start up's in the mornings.
I have checked every thing (not).
had replaced the water in the fuel sensor three days ago and had easy start ups untill today so i was checking things out some more and found that the hose cuming from the return side of the pump was old leaking fuel and running down the back side of the fuel fillter and down the sensor. i think this is what is causing the hard start probs (fuel pressure leaking). i'am going to get fuel line in the morning and see if this will fix it and let ya'll now if this is the fix. :rolleyes: :rolleyes: :rolleyes:
thank's to all that have helped me so far.
Edwin
Hey Edwin, Glad another Texan is onboard the TDR. A word of warning, be sure to get diesel rated hose. Normal gasoline hose will work for a while, but you will probably be replacing it within the year. One better would be hose that is Coast Guard or Marine rated. It can be found at Boating supply stores (West Marine or Boat Superstore) or something else local to you.
You might as well replace the supply line while you are in there. One bit of advice is to drop the starter, it makes things much easier. Good Luck... ... .
we'll i went to napa and got some hyd hose and put it on. right off the bat no leaking fuel. off to a good start. we will see come morning but i think it's o. k:) ;)
