I have posted on here several times over the last months that I have a hard starting problem, when cold. But it would start fine when pointed down hill. I have replaced the following
Lift pump
Fuel lines to tank 2x's
Fuel line from Lift pump to Filter
Banjo bolts
replaced all clamps
Finally here is the latest. I put a check valve in line between the lift pump and the fuel filter and it seems to have fixed the problem. I don't like this answer because it is a work around. Can any one tell me if this could create a problem? My pressures are still the same at the VP44.
Lift pump
Banjo bolts
replaced all clamps
