Hello.
I have a '96 2500 that has progressively gotten tougher to start in the mornings or after it sits for a few hours. It takes many cranks to turn over which is only causing frustration and an eventual need for a new starter motor.
I've looked through the postings and have found some feedback relating to either the fuel overflow valve or the fuel lines. I don't see any fuel dripping or areas around the fuel line that are damp but some of the fuel line disappears when connecting to the fuel tank. I have seen mention of cracked return lines which can allow air to get into the system. Is the replacement of the fuel line something most anyone can handle. I'm mechanically inclined but a diesel novice.
Regarding the fuel overflow valve. Is there an easy way to check its operation before replacing it. My dodge dealer in Durham says he has never moved one through their business. It's a special order part and I would prefer to check other areas before committing.
Thanks for the replies in advance.
Regards,
John
'96 RAM 2500, bone stock
Raleigh, NC
Regards,
John
Raleigh, NC
