The other day my 99 dodge developed a hard start condition... . It started up fine when I left to go to the store and then when I left which was about 5 minutes later I had to crank it about 10 times before it would fire over... I tried changing the fuel filter and it starts a little bit easier but not much... If I park my truck on any kind of a slope of more then a few degrees it usually takes about 5 minutes of cranking and waiting before I can get it to fire over... I came outside this morning after the truck had been sitting for about 8-10 hours and it fired right up after 2 cranks... Most of the time if I turn the key of and crank it a few time then let it sit till the lift pump stops running then wait an additional 5 seconds or so it starts tight up... . Occasionally when I finally do get it started the engine seems to surge untill it bring the RPM's up to about 2000 or so and hold it there for a bit then let it idle back down... ... . I looked under the hood for any fuel leeks or wet spots and didnt find any... . I had the lift pump replaced about 4000 miles ago... . Any help would be greatly appreciated...
Moose
Moose
