Hard steering
Valve Body For Me???
2001 Tach Markings
My power steering seems to have taken an unplanned vacation. The fluid level is at the full mark and the front tires have 55lbs of air in them. When trying to manuver in a tight parking space or other slowspeeds it almost feels as if there is no power assist at all. waaaassssup?
Bright Red 98. 5 2500 4 X 4. 285R75 16 2"lift in the front to level it out with a 8264 Warn wench. Hiway aluminum 5th wh. tool box. 32'Alfa 5th wheel w/2 slides. 1 pair of black truck nutz under the rear because it's a RAM not a ewe. K&N air filter,soon DDT tc/vb
try letting of the brakes when you want to turn. the brakes and steering work off the same pump. night have the dealer check it.
This is happening even when I don't have the brakes applied. What's weird is that it doesn't happen all of the time. Dan
Dan,
I have been experiencing the same problem on an intermittent basis since DC replaced my steering box about 3 months ago. I'm wondering if it is possible to have air trapped somewhere in the system. If you figure out what it is, let me know. Thanks.
Steve
