Ever since I put in new ball joints and front axle joints I have heard and felt this noise... . it's a slight vibration almost sounds like a tire rubbing on a mudflap. It only happens once in a while and only in a really slow speed turn..... any ideas? I don't want to throw parts at it either. No play in the hub bearings... . maybe a brake shoe in the back? Could it be one of the new u-joints are bad (I bought Spicers). PS pump or steering box? Hubs and rotors are a couple years old...
I was doing a little testing last night with different scenarios. It only happens under 10mph... ... . more so when the wheels are turned to the left and it does it no matter if I am driving forward or reverse. It does it randomly when turning right but it's random on both directions. I keep going back to the hub bearings and axles/ axle joints. I remember yelling at my buddy for whacking the back of the rotor with a 2x4 and hammer to remove the hub..... I am wondering if he f'd up the hub with that? He was working on the left side while I was pulling the right side when we were changing the ball joints. I also noticed with the left side jacked up and no load on the wheel I can hear what sounds like a U-joint clicking but it's coming from the diff. I am wondering if the bearing is transferring sounds through the axle shaft? I'm going to pull the front diff cover and check for debris to make sure the pinion bearings and gear set is okay but I am leaning towards that hub being hosed now from him beating on the rotor.
