How new are your front u-joints? I had the same problem w/ stiff steering causing a wander due to oversteering, played w/ the adjustments on the gear box with no success.
I then jacked up the whole front end and manually moved the steering and could see the drivers side u-joint binding.
Replaced both of them and now the truck steers smooth and easy.
Hope this helps...
