Hardlined Wastegate Fix?????
Does our engine fan cycle on/off?
Cracked Fuel Filter
I have a 2001 auto with the small 9cm2 turbo that has the hardlined waste gate. I recently installed a Power Edge and now I need to fix the wastegate so I can get more boost. I have tried to get the j-hook from TST or the little plug thing from DD and neither of them sell it seperatly from the boost module. So we need to come up with a solution. I don't really want to buy a new turbo (yet) and I would prefer to retain at least a stock appearence. Anyone have an idea??
01 2500 SLT+ QC LWB 4x4 Auto 3. 54 rear end Forrest Green Sport with all options avail
DC Nerf Bars, DC Grill Gard, DC mud flaps, Line-X bed liner and Leer 160XL Topper
Power Edge equiped. SPA Boost/EGT Gauge ordered and 4" Exhaust in planning stages. Dreaming of transmission up grades and injectors... ... and some type of Airbox mods.
See My Truck
2000 Skidoo Summit 700
Dads truck: 98. 5 3500 SLT QC LWB 4x4
Brother Truck: 92 W250 SLT CC LWB 4x4 (Dads old truck)
See 5 Diesels and a Gasser
JR2,
I am in the same situation. The most boost I get with the edge on is 20-21. HVAC has kindly provided me some advice on where to start.
We will have to remove the actuator from the turbine, then either fit a restrictor inside the "pipe", or epoxy it closed and drill a small opening. Also need to drill a bleed hole between restrictor and actuator. I have not yet tried this, and am ALL EARS to anyone who has.
Dave
2001 2500 ISB,4X4,QC,SB,AUTO,3. 55's,BLACK,AGATE LEATHER,SLT,every option except heated leather/4whl anti
Ok, make that three... I'm in the same boat. My PE is on it's way. In my stock form I hit 20 lbs of boost.
How does the PE feel on an otherwise stock '01 auto??
'01 2500 SLT+, QC, LWB, 4X4, 3. 54s, AT, SPA guages, Alpha Liner, Stolen Silencer ring, every option but running lights! To come: DD Stage II's PE or DD Boost Module, Exhaust brake, 4" turbo to tail, etc...
'98 DUCATI ST2 "Bombed" 944CC with Ducati Performance Carbon Fiber Exhaust, F. I. M. Chip, K&N and "modified" air box.
<font color=teal>Wouldn't be possible to drill a small hole in this tube to bleed off the boost and keep the wastegate closed longer. This is partially how the TST elbow works on my 12 valve it resricts as well as bleed some(very small hole) of the boost off. </font>
Dee'sel
97 2500 Club 4X4 3. 54, Forrest Green/Driftwood, LSD 5 speed, K&N Air filter RE0880 & Psychotty, TST #11 all the way forward, #12 for winter, AFC spring kit, Geno's Exhaust Blanket, TST EGT gauge & TST 0-60 boost gauge in A Pillar, Hypo clutch ass. , Cat-be-gone, 4" Dynomax Bullet muffler, Crome 4" turn down, AmsOil GL-4 80W-90 in Trans , AmsOil 15W-40 Oil W/ Bypass system, AmsOil Ser 2000 75W-90 in front & Rear ends,
Lund WInter front, Leer Cab Level Shell Driftwood , 235/85R16 Goodyears, Dyno'd 342 HP *NRA/USPSA member and proud of it*
<font color=blue>My solution is to run it stock for now. When I get the injectors added I will toss the dinky 9cm turbo and replace it.
Although I may try to modify the wastegate a bit before doing that. Its still kinda up in the air, the 4" exhaust might hold my temps down and not require the "extra" boost for cooling purposes with just the PowerEdge. Guess I'll know by Sunday. Exhaust is here!
Daveo-
HVAC told me the same thing, except he told me to make it a removable plug. I may do this I am just not ready to plug and drill, I am waiting for a more elegant fix.
Scooby - just wait, you will like it. I have posted in the massive power edge post about how it feels so I will leave it at this. YOU WILL LIKE IT.
Drawson - I don't know why drilling a small hole wouldn't work, it may not let out enough pressure. I think the other part of the normal boost elbow is a restrictor of some type.
Kat - let us know what happens, I am planning on injectors this fall, will probably run this winter with the PE off as extra horse power and ice do not mix well. I am getting the injectors because they make the truck start easier and run a bit better in the cold (this is according to a DC service manager).
I wonder if I can buy just the actuator-hardlined piece at ??? and modify one and still have a "warrany" one?? :)
See My Truck
Machinest,
Sounds easy and logical. Thanx from all of us stuck with this problem.
Dave
Sounds easy enough. I will have to find that small drill bit and some small wire, should not be too hard. What kind of epoxy??
If there is any one going to a cummins shop today, could they check and see if you can buy just the hardlined piece for the turbo, I want one to practice on and I am a long long way from a cummins dealer right now. I know they will ask "why do you want that", tell em you crushed it removing your oil filter with a pipe wrench.
See My Truck
[This message has been edited by JR2 (edited 07-29-2000). ]
I might note that when we modified Mike Crossley's turbo, we tested it and found it took 80 psi to get the wastegate to move! I am not sure you need to drill the plug since the pressure which would get through the restriction would seem to have no effect on the wastegate operation. I would think the bleed hole in the tube might still serve a purpose in that it would allow air to enter the tube so as not to hamper the diaphram moving/wastegate opening at high drive pressure levels (WOT).
BTW, most drills won't chuck up tight enough for teensy bits (035). Your trusty Milwaukee may not work. You may have to take your turbo actuator to the dentist for modifications #ad
[This message has been edited by HVAC (edited 07-29-2000). ]
HVAC That is an appointment 4-6 weeks plus 50-100 u. s. skins ----DENTIST-----
Your right on the drill unless you have the high tech MACHINEST TOOL'S
GOOD RAMMING FUEL=BOOST DEVCON EPOXY STEEL GRADE*******************
[This message has been edited by MACHINEST (edited 07-29-2000). ]
Mark Smith and I just installed DD stage 1 and the restrictor plug from DD for 25. 00. On a 2001 auto with the hard line and am getting 32 psi of boost. #ad
The only question we have is how to get the rubber plug back into the turbo housing? Should it be inside the housing or between the tube and the housing?
Eric Pitts
2001 Properly Valved 2500 Qcab 4X4 auto Transgo shifts it
4. 10 LSD Prime-Loc
Weston Nerf Bars
Smith built brush guard
Command Remote Starter Scotty Air
Neophyte B. O. M. B. er
Terre Haute Indiana
The Pitts Home Page
Member GLTDR
Eric Pitts
4. 10 LSD Prime-Loc
Weston Nerf Bars
Terre Haute Indiana
The Pitts Home Page
Member GLTDR
top
Eric Pitts
4. 10 LSD Prime-Loc
Weston Nerf Bars
Terre Haute Indiana
The Pitts Home Page
Member GLTDR
Wanna buy a stock turbo from my 12v'er??
It's in very good condition and has the 12cm wastegated housing on it.
Asking $350..... #ad
'97 FL60,5. 9 cummins,marine pistons(15. 0:1compression ratio),thicker head gasket,300hp. diamond"b" injectors,HX40-16cm2 turbo,custom grind fuel plate,4"straight exhaust,no grid heater,44psi of pure pleasure!!!!!!!!!!!!!
&lt;&lt;&gt;&gt;Charles Pyatt&lt;&lt;&gt;&gt;
CATERPILLAR... yeah, they do move pretty slow!!
