a buddy is going to try this. i thought i saw some mention of it not to long ago. wondering how it turned out. any thoughts? thanks
dave
dave
ThrottleJockey said:I got all the parts. Robert Yoke is my hero. Did you bypass the brake with an external wastegate and did you use a spacer off the manifold for it, Robert?
Huh? Didja?![]()
Thanks, Brian
Jeff_K said:I am planning to do something similar to Roberts setup sometime this summer. I have the same top turbo and pacbrake. I was going to add an external wastegate to the setup for better boost control, but I don't think the exhaust brake would work very well with an external wastegate in the loop unless it is tubed in upstream of the brake. If you bypass the brake with the external wastegate, as the backpressure builds in the engine when the brake is engaged, the pressure will just be relieved through the wastegate limiting the amount of back pressure to the size of spring in the wastegate (i. e. 20psi).
robertyoke said:... if you pressurize the top of the external wastegate with the same line that feeds your pac brake it should keep it closed.
