I used to have the Bosch 275s, VA, DD Boost Module and Banks wastegate actuator (pre Big Head) set to 28 psi and had virtually no smoke! Many NW BOMBers can attest to that.
I removed the VA and Bosch 275s in favor of the DD3s... I'm still glad I made that decision. A little smoke, but not objectionable. One thing I noticed, after replacing the DD wastegate fitting (with bleed orifice) with the OE brass elbow AND Banks Big Head wastegate actuator, my boost came up quite a bit faster.
I should also point out that was at the same time I installed my ATS exhaust manifold and Banks 14 cm2 turbine housing.
John Treibel
'98. 5 2500 QC 4x4 Sport, Glasstite Vision II, 285 BFG A/Ts on M/T Challengers, Warn 4X Boards, Mopar fender flares & tow hooks, NW Custom s/s-rubber mud flaps, Mag-Hytec diff. cover & trans. pan, Edelbrock IAS shocks, Reese Titan V hitch, SPA gauges (3), Dynamat, '00 Sport grille and headlights/PIAA Super White bulbs, PIAA Dual Sport 900 aux. lights, BD exh. brake, Amsoil Dual Remote Bypass, Optima Yellow Tops, DD3s/DD Boost Module, Aeroquip AQP braided s/s fuel hoses, Banks High-Ram intake manifold and 14 cm2 turbine housing w/Big Head wastegate actuator, ATS 3-piece exh. man. , Banks 4" dia. s/s exh. sys. , BD modified trans. front pump, Air Bulldog induction hood (with NACA ducts), plus MANY other trick modifications
Recycle Bin: Prime-Loc fuel filter relocation kit (due to flow restriction), Bosch 275s & VA CPC (upgraded to DD3s... WOW! what a difference!), '00 Dodge/Cummins valve cover (going back to my OE '98. 5 valve cover... tricked out though), VDO Vision gauges (upgraded to $PA gauges. . three of 'em... where's that
when you need it? LOL)
[This message has been edited by John (edited 01-08-2001). ]
