Hastings BHAF....Any Good?
Normal % of fuel in the oil????
Can't pass this one up on EBAY---------
Hi All,
I live in a small town and have a hard time getting parts without having to drive 70 miles (one way) to pick up a Fleetguard... . Does anybody here have any experience with Hastings ( I can get it locally)... Is this brand any good?... . I have heard that some airfilters require a pipe to be inserted to into the filter opening so the clamp won't crush the filter inlet. Is the filter inlet on this filter stiff enough as is? NOTE: I can also het the NAPA locally... . would this be better?
Thanks for your help
Andrew
here are the part #'s
Fleetguard AH19037
NAPA 2790
WIX 42790
Donaldson B105006
Baldwin PA2820
Hastings AF1012
DONALDSON ECB105006
IVE ONLY USED THE NAPA IT WORKS GREAT WITH NO NEED IN A PIECE OF PIPE
Some of the mentioned filters are water proof the napa is not Id recomend an
OUTERWARES
P/N: WR3325-105BL-$30. 00 WR=water resitant BL= blue
1-800-967-3450
just tell them its for the BHAF - napa 2790
$50 for the filter $30 for the outerwares and If your interested PM me and Ill send you the Heatshield template
DM
Bear in mind that the BHAF flows rather pitifully compared to an aFe or other performance filter.
Where the BHAF lacks in flow... it gains in keeping the air clean. They only flow a little better than the stock airbox with a stock filter... but every little bit counts.
The best of both worlds is the aFe Pro-GUARD 7. It's 7 layers of high flowing, excellent filtration, diesel happiness!
Matt
Matt are you sure about that? I thought I remembered reading a post sometime back, can't find it now :rolleyes: that compared the BHAF to the stocker and it flowed considerably more air. I'll see if I can dig up the info I thought I had.
Jim: That was a good link. Way more information than I've ever seen posted about an air filter comparison...
You can nit pick some of the things they're saying in there - as it seems like the whole idea was to prove that the OEM filter setup is good enough for most folks.
Ryan: Now that you mention it - I can't find the results I read a while ago. The results were probably on an aftermarket air filter manufacturer's website. :)
Matt
What about running two Fleetguard BHAFs, assuming necessary room? I don't know how to calculate flow. And by two, I mean two plumbed into a "Y" then to the turbo.
Just going off memory here, but I thought Joe Donnely ran some flow tests a few years ago and found the stock box aroud 400 cfm and the AH19037 over 600 cfm. The test was in the TDR magazine a few years ago, way too long for my memory :rolleyes: I could be wrong.
Jared
Heres a few more BHAF#s for DMs list
BHAF Part numbers
Fleetgaurd # AH19037
Wix # 42790
Napa # 2790
Carquest # 87790
Donaldson # B105006
Baldwin # PA2820
John Deere # PMAH19037
Big A # 93790
CATERPILLAR# 3I0005
FLEETRITE # AHR819037
HASTINGS # AF1012
LUBER-FINER# LAF2531
Jared
It has been done... sorta. I've always wanted to run dual fender mounted air cleaners... just like the big rigs. They also run 7" (!) intake pipes on a lot of those OTR trucks... :cool:
Matt
Fleetguard AH19037
NAPA 2790
WIX 42790
Donaldson B105006
Baldwin PA2820
Hastings AF1012
DONALDSON ECB105006
OUTERWARES
1-800-967-3450
DM
Go to www.filter1.com
They have BHAF for $29 and change. You may have to set up a business account, but you can fudge a little bit on that.
-Will
