Hauling a baby seat in Club Cab
Electrical rqmts for CTD operation - 1st Gen
Crank shaft Seal
I would make a center belt or seat mount . . DO NOT mouint the seat sideways. . as the infant can be killed very easily do to g forces on the neck and head... With your back ground a center seat retrofit is gonna be a walk in th epark no too hard and way safer then sideways outboard mounting of the seats on the stock jump seat. . BEST to be safe then sorry. . If my child was ever killed or seriously injured do to the way I placed them in a car seat or mounted the seat incorrectly. . I'd have to live with that for the rest of my life. . not worth it. . ie do th ecenter mount and have them face backwards...
Thanks,
deo
Still talking things out with the wife. No intention of trying use the back jump seats for the kid. We have six weeks to go before the kid comes. Thanks for the input. The vehicle is not the families primary mode of transportation and it wouldn't be often I would need to load up the kid. I am still debating on upgrading trucks to a '98 12 valve with quad doors. I think that would make the most sense for all. I don't "want" to get rid of the truck. It just might be the best all around. Thanks again.
Dave
I feel your pain man. Went through all this when my kids were born and it's still happening(even at ages 4 & 6). They seats are not safe or legal sideways. Make sure you check your local laws well. Police may not even know the current laws.
If your truck is a stick it won't work in a front center bench, unless you grow an extra elbow. You might try mounting a 93-94 dakota bench and center belt in the back(some even have matching upholstery), but it will only work until you need a booster. The seats work fine in our 01 quadcab and I'm 6'2" and 350lbs in the front seat. Rear facing will have to be in center, boosters on the outside.
The real problems start when you need a booster. Boosters are required by law most places, but are not legal without a shoulder belt. Wyo requires a booster until age 8 and 80lbs. Here in Alabama it's 6 and 60 lbs, but it's more complicated than that. There are no grandfather clauses for older vehicles. Kids can not legally ride in an older vehicle until it has been retrofitted with lap/shoulder belts. The new law also makes no exclusion for front seats in vehicles without airbags. Regardless of the studies, my booster seat child is safer in the front seat of my 85 crewcab with a shoulder belt and no airbag than in the backseat with no shoulder belt. The law does not care and luckily it is easy to retrofit rear shoulder belts into as the mounts and braces are already there.
But what do you do if you own an older van, suv, or car. I was told I had to buy a newer car and it was just the price of having a family. They make junior dragster seats that are kid sized and have 4 or 5 point belts but they are not legal. They make retrofit belt systems for bus seats including vans, but they are not legal for private use. :mad:
The solution for my ramcharger is a third row seat out of a 2000 suburban with built in shoulder belts. The only other way was to put in a roll cage to tie the belts to or salvage belts from a 91-93 ramcharger. While searching for a donor, I found this suburban that came out of a pond. I only paid $25 for the seat since it needs alot of cleanup(but everything works). Unfortunately, these seats are usually $250-$500 even on Ebay. I will have to build new mounts for it, but that will be easier than a cage.
If the lawmakers were really interested in the safety of our children they would force the seatmakers to sell solutions for people who own older vehicles and subsidise the initiative to get them out there. They can do that for a new digital tv system but not for our kids. #@$%!
The most recent reason why I still believe in car seats.
Me wearing my seatbelt, Logan in his booster, and Duncan in his carseat. After hitting a semi, we were lucky. Logan had a nosebleed from high blood pressure, we all had a little belt rash, and were sore for a few days.
Wow. Thanks for the post, and pics. I never intended to use the sideways seats. The car seat has hooks and a belt that goes horizontal to the bottom of the seat; the LATCH system. I just need to install u bars in my cab, in the center of the extended cab. I am not totally sold on this idea though. I have friends who think this is a bad idea. So again we might be back to looking for a newer truck. Installing a seat from a Dakota would render the back almost useless, except in the center between the captains chairs, as the seat back would interfere with the kid seat.
Thanks for the ideas.
dave
Latch is a good system. Probably the best system for mounting a carseat. If you decide on retrofitting to latch consider adding a forward tether point to stabalize the seat. Also, you should probably consider investing in some type of seat to install. If you direct mount the carseat to the floor, the baby is going to experience all the shock and vibration that the truck dishes out. These trucks are not known for a soft ride and the seat absorbs alot. That being said my kids traveled and slept better in the diesel. Also, probably is not legal to strap to floor.
