Had a new lift pump and ip installed in July. Just got my gauges installed. When key is turned to run, fuel pressure might come up to a few pounds. Once engine is running, pressure will rise to 12-13 lbs. After running for 10-15 seconds, fuel pressure will drop quickly to 3-4 lbs and sit there. When driving, it will sometimes come back up. I am using ISSPRO gauges with a fuel pressure isolator. Is it possible that I have a pressure delivery prob within the gauge tubing? I figure that if I'm seeing the 12-13 lbs at first, the gauge setup must be working correctly. Does the lift pump tend to kick on and off? Any input is greatly appreciated...
Eric
Eric
