With the G30 recall plus the total replacement of the EGR Valve, Cat and the DPF the engine does sound more like a diesel and the milage has slowly climbed back up. However running around town the milage is worse. The engine is much more responsive in all stages. There is no smoke, ever, there is now no burnt rubber smell on shut down, or at any other time. When all is said and done, this is where it should have been on day one. Yes the oil is black as coal, yes it still has a shine to it. The Active Regen cycle lasts about 15 minutes. The Overhead console milage readings are much more responsive to the driving condition or style. There are some fueling issues which could be resolved with better and finer fuel filtration with air separation which will be my next mod. I have added by pass Oil Filtration as a means to reduce the heavy soot contamination. As to the rest of the truck, the only other problem developed at about 60,000 Km and is now being replaced is the HVAC unit, the motor appears to run slower and the quality of heated air has reduced (Warranty item). In all I am very pleased.
