So I purchased a 2002 dodge 2500 24v cummins work truck a couple months ago. Truck ran great, I drove it for about two weeks with no problems until one day while driving it just shut off and would not restart. After diagnosing I noticed there was a lift pump code and I couldn't hear the lift pump running. After further investigation I realized there was no lift pump at all on the truck and only a sending unit in the tank! It has the wiring for an in tank lift pump so I purchased an in tank pump which is working properly and getting fuel to the IP. I cracked all the injection lines and just a trickle from the lines after cranking for a couple of hours. I decided the pump must have burned up with no lift pump pressure so I pulled the vp44 off of another cummins that I wrecked about a month prior and installed it and I'm still not getting fuel!! After two days of cranking and checking lines ect.. I was at my wits end so I used ether. The truck starts with ether and injector line #1 pumps but that is all. Does anyone have any suggestions? There is 12volts to the pump with the key on and it drops while cranking but still has voltage.
