Vaughn MacKenzie
I recently acquired a '96 12-valve with a slightly leaky headgasket (small coolant residue visible on right side near cyl #1).
I want to pull the head, possibly port it, but my initial plan is to stick with a stock headgasket replacement. I heard that the gasket has been improved considerably over what Cummins was using back in '96.
Here are the questions I have:
1) I see some shave their heads . 010" is this necessary? What is the point of doing this, to achieve better injector position when going with a thicker head gasket?
2) How much boost can a stock gasket maintain? I don't want to fool with O-ringing and don't plan on running more than 40-45 lbs.
3) What are the pros and cons of doing 12mm studs? I read in a thread there is a risk of block distortion using studs, how much of a concern is this? Do stock bolts (planning on new ones) hold reliably to the above mentioned boost pressures?
4) What is the main reason going with thicker gaskets to drop compression? Reduce peak cylinder pressures? What are the drawbacks? What about going . 010" thicker gasket? I heard the copper ones are a poor choice for those who don't want to mess with gaskets every 50-100k miles (I want to do it once and forget it).
Studs would be nice, would rather not spend the bucks though, and I don't want to risk distorting the block & cylinder bores and create more oil usage and blowby or accelerate wear. We are talking about an engine with 352,000 miles so I don't want to upset well-established wear patterns.
I am going to assess the health of the internals when I pull the head so I'll know how sound this motor is, and if it's up to some "bombing. " It runs good and has very little vapor coming out the blowby. When the engine is fully warmed up and I block the vent hose it doesn't build pressure very fast. I suppose I could mic the bores to see how much wear there is. Is there any accepted wear limits?
My plan is to go with about 350-375hp to the rear wheels and call it good. No plans to go hog wild or put twins on or the like. Still would like to get another few hundred thou out of it.
Thanks all,
Vaughn
ps it's a '96 4x4 CC longbed, 215hp 5-speed
Thanks all,
Vaughn
