Engine/Transmission (1998.5 - 2002) head lights dimming
2nd Gen Non-Engine/Transmission Error code history
Engine/Transmission (1994 - 1998) Power upgrade
ok I have noticed a new problem when sitting idle my head lights will dim then go bright the only thing I can think of is my ac fan is doing this maybe pulling to many amps? any suggestions? what I might be able to check to see why my lights are doing this.
If it is just after start-up, it's probably the grid heaters cycling to help warm the motor.
Randy
You have 2 grid heaters under your hood that draw around 90 amps each. Believe me, 180 amps @ 12 volts or 2100 watts, will cause your headlights to dim. It's normal.
Kevin
