The only problem,I see with not pulling the head,to install studs is, you cannot run all the studs all the way to the bottom of the hole,because the threads don't go deep enough in some holes. You usually need to run a bottoming tap in the threads to extend the thread depth Which causes two problems,not going all the way to the bottom. One is the stud will stick out too much causing clearance problems. The other problem with that is, studs need to pull from the bottom of the bolt hole because its stronger that way. The block is stronger deep in the bolt hole,than near the surface.
