Headlight adjustment
Surge at Idle
Warm up/cool down
My first Diesel hauler, I'm just learning about it. Should be a simple ?, I think. On my 04. 5 Dually, where are the headlight adjustment screws. Driving down the road at night, I look like I'm searching for snakes. ;) Also, how do you guys get your cool names added and the vehicle descriptions? Thanks
I've got an '05 and switched the OEM bulbs for 9007 Osram/Sylvania Silverstar after first drive at night. I'm probably wrong, but I don't believe the headlights are adjustable. The best driving light effect I've realized is when I slowed down. Auxillary lighting would help on the Interstate. Can't help with your signature ( can't do my own ) but there is an edit function on the main page I've attempted. . I know you'll do better. Hope you enjoy your truck as much as I do mine.
To add a signature line, Click on "Discussion Forum", then click on "User Control Panel", then "Edit Signature".
Juan
All headlights, by law, must be adjustable. I have an older horse but somebody will come on for you. They a probably in the same place but I don't want to lead you wrong. Enjoy the truck!!
There is a black weather seal on the inside edge of the light. Pull that over and you will see a torx bolt you can tighten or loosen to raise or lower the light beam.
Hope that helps.
Both the headlights and foglights are adjustable. I forget if you need to rotate the adjustment screw clockwise or counterclockwise to raise the beam. I do remember that it is the oposite for the fogs. I guess they come from the factory pointing at the ground so that when you load the back of the truck they aren't pointing up too high.
Thanks.
Hope that helps.
IT WORKED !!! Thanks for your help
