I got tired of driving with lousy visibility when using the High Beams--I wanted the Low Beams to come on at the same time the High Beams were on without burning up my headlight switch! And I didn't want to spend the money for one of those "boxes"... so this is what I did.
OK... I bought a Bosch 30A relay and also a wiring harness for it. Pep Boys or Auto Z. probably don't have this stuff. Napa might. Any good relay will work, and you don't have to have a wiring harness for it, but it helps simplify things.
Or you can order the Bosch Relay and a Wiring Harness for it from a place called M. A. D. Enterprises. They are a speciality 12Volt Wiring place for car nuts. The relay & wiring harness are more expensive through them, --but they also sell an Insulated Terminal BLock which makes the job go a lot easier. They sell the Terminal Block for $5. (I got a few of them) Their phone number is (559) 539-7128 their website is Madelectrical.com
First I scouted a place to install the Relay--I picked a place near the driver's side battery and drilled a small hole into the sheet metal to take a screw to hold the Relay. I also drilled another small hole nearby to hold the Terminal Block.
I needed a source for 12 Volt +. I used the MadElectrical Terminal block, and ran 12V+ to it by soldering a 10 Gauge wire into the Positive Battery Cable and then running the 10 Gauge wire to the Terminal block. (The Mad terminal block has plenty of room to safely add other electrical wires to it if needed for future additional electrical goodies. ) I suggest you also install a fuse in that 10 Gauge line.
In addition to the + Batt Cable, there are 2 other places where I stripped insulation from existing wire and soldered another wire into it. At these solder joints, I used Liquid Electrical Tape on it, and after that dried, I also used 3M electrical tape to keep the elements out.
Ok... now for the wiring:
The idea is to use the High Beam current-flow to trigger the Relay so that the Relay turns on the Low beams at the same time. Then, when you hit the multifunction switch and dim the lights back to Low Beam, no current goes through the Relay and the High Beams stay off. All this without adding any appreciable current load to the Headlight Switch.
So you will have to determine which wire sends current to the High Beams, and which one sends current to the Low Beams. I used my Service Manual wiring diagrams, and confirmed which wires were which with a tester. I had to pull some of the tape off the Headlight Wiring Harness, which runs below the Radiator. I separated out both the Low Beam & the High Beam wires and MADE SURE they were the correct ones with the tester.
Then I stripped some insulation off of each wire, I soldered in 2 lengths of 12 Gauge wire--1 onto the High Beam Wire, another onto the Low Beam Wire, long enough to be routed back up to where my relay was installed near the driver's side battery.
Then I wired the Relay. I ran 12 Volt + from the Terminal Block to the wire for the #30 connector, and I ran the Low Beam Lead to the wire for the #87 Connector. I wired the High Beam Lead to #85, to trigger the Relay and Grounded #86. That did it! I tested it and I'm driving happy at night now!
