Details here: TDR Privileges
Anyone notice their headlights getting brighter or dimmer,especially when the truck is just started?My guess is that it is the alternator charging up the batt's... but it's my wife's truck and she worries, you know? #ad
Originally posted by -gtsm-: Anyone notice their headlights getting brighter or dimmer,especially when the truck is just started?My guess is that it is the alternator charging up the batt's... but it's my wife's truck and she worries, you know? #ad
gtsm ,
the reason the lights dim and go bright is
do to the fact is that the intake heaters
is heating the in coming air to allow the the engine cylinders to have warm air for combustion. the heater grid does pull alot
load.
To confirm what every one is saying. You should see the lights dim and the voltage gauge indicating a discharge . . about 5-10 seconds later you'll see the lights return to normal and the voltage start to rise.
I usually notice this activity when the temps fall below 40. If you're in the 70's like we are in the south . . and it still cycles . . you may have a problem.
But . . more than likely . . it's the grid heater's cycling . . normal
Michael
00 Driftwood 2500 ST QC ISB LB 5spd 3:54 LSD Tow & Camper Groups . . SunnyBrook 33FKS Travel Trailer
If "everyone says it is normal" doesn't convince her, you can find this in writing in the owner's manual (at least in the 2001 manual). Repeat after me: "I told you so. " "I knew that. " "Maybe next time you'll believe me. "
P. S. - DON'T LISTEN TO ME!
