Hey guys, what is a brite box? Is it something that allows you to keep your high, low and fog lights on all at one time, like when you hold the lever all the way back? Also where can you buy one of these? Thanks
If you don't drive in the fog much, you could try this mod.I've been putting up with my '03 since new, have the Brite Box, etc. , but nothing works well for down-the-road seeing because the reflector is the problem. Thanks a bunch.
They are mounted in the hole where the fogs once were, they are fully adjustable and are aimed using aiming equipment same as you would for the oem headlamps and are aimed as a high beam lamp.So precisely where are they mounted to shine that far down the road?
While on this subject, would someone who has changed the bulbs, please pm me with how to remove the lens to change the bulbs?
Thanks.
Thanks.
