Heads Up Display anyone???
ladder racks???
Isspro guage rattles after 20# of boost?
So what do you guys think about a heads up display for your vehicle speed Tach, boost presure???
I ran across this compnay and they have one that will work on our trucks, only problems are that they are in Bar for Boost, and limited to about 20 PSI (converted) but I am in contact with the manufacturer to see if they will make a Us version for the boost, the speedo will work as is. Cost is about $250 anyone think this would be cool other than me? If so let me know as I may become a dealer if they work this stuff out...
http://www.defi-shop.com/bootimer/botimfrm.htm http://www.defi-shop.com/vsd2/vsdframe.htm
TAZ... 2001 2500 SLT+ 4X4 Auto ETC Cummins, LSD 3. 54,Quad Cab, Long Bed, Agate Leather, White/Driftwood Exterior, Sliding rear window, Camper Special Group, Towing Group, Cab clearance lights,SPA-Technique Digital Dual Gauges (Pyro/Boost, Trans pressure/temp) Aux. Backup lamps. BNM 5th Wheel Hitch, Additional Body Molding on Bed. Line-X bed-liner. DTT's TC & VB, Pac Brake w/ DTT Smart Controller, Power Edge, Edge EZ, Grover Air Horns, P. S. High Idler, RV 275 Injectors.
2000 32' Aljo Triple Slide 5th Wheel.
Ram-Taz
[This message has been edited by MCrossley (edited 05-10-2001). ]
I am definatley interested. My boost only goes to 20 so thats fine. How do i order and how do i interface it to the Tach and Speedo, etc?
i would prefer EGT and fuel pressure , heck boost and trans temp also , then i wouldn't need to take my eyes off the end of the dragstrip .
Excellent point guys, like I said I am already in the works with communicating with these people, If I can get past the first hurdles of what already exists, I am hoping to have them work on developing a system that would include ALL crucial data in this type of display.
Ram-Taz
I'd love one for my 78 Vette!
http://coffeewithJesus. homestead.com/web1.html 89 1-ton, Amsoil System 3000 5-30,K&N, cleaned-up exhaust with Dynomax straight-thru, rebuilt injector pump, thermostatically controlled twin 14" Permacool electric fans, intercooler, modified 518 OD transmission, Gear vendors OD controler, Reese Titan 2. 5" receiver, R-134 refrigernt, louvered front fenders, 93 aftermarket smoothie grille, new Dupont Chromacolor black, black-and-red rubber rubstrip, black headlights, powdercoated bumpers; 78 35'Avion, 93 Lance 900 slide in with generator and power jacks. To see my truck, Click on: http://albums.photopoint.com/j/AlbumIndex?u=1169022&a=10097213&f=0
Jesus saves!
$250? Sign me up! I would like to see boost, EGT, speed, and idiot lights would be fine for all the rest. I am assuming it uses information from the ECM to display, so how are you going to get boost info when a guy is using a boost module? Let us know what you come up with from your conversations with the manufacturer.
I'm likin this ALOT!! Tach and EGT is all I really need, idiot lights for oil pressure, and fuel pressure (settable) would be nice too (but not necessary). Forget the other stuff, too much info in a HUD is confusing IMO. When drag racing or off roading it's hard to take my eyes off the track or the trail so it would be nice to be able to see the truly critical stuff through the glass! Maybe they could put everything everyone wants on there and you could choose to turn off the ones you don't like. I'd even pay more than $250 for it (sounds cheap to me).
-Steve St. Laurent - President of the Great Lakes TDR
'98 QC LB (CMNSPWR), 4x4, ISB, 5sp, 4. 10 LSD, TST Powermax3, 275hp RV injectors, Joe Donnelly modifed Sachs Clutch, SS ladder bars, SW fuel pressure gauge, BD exhaust brake, Isspro turbo temp monitor, front Draw-Tite receiver, rear Draw-Tite class V receiver, BFG 285/75R16 AT KO's, (all the common stuff clipped)
[This message has been edited by Steve St. Laurent (edited 05-10-2001). ]
Looks nice. One queston though. Sittin in the dash like that, what is the sun going to do to it on a really hot day? Do they guarntee to a max temp operation? I already fried one GPS unit.
Mundgyver : 2001 - 2500 QuadCab 4x4 139"WB, DK. Garnet Red Pearl Coat, Agate Inerior, Leather w/heat power adj both sides, 5. 9L HO 245Hp, 6 spd HD Manual, 3. 54 Axle, 21 Mpg Avg in town 24 Mpg Hw, OverHead Trip Computer/AntiTheft System, Mopar Tow Group Package. Add-on = EZ-Box=Haulin Butt, AMSOIL, PIAA SuperWhite 9004 HL's, Acrilic Black bug deflectors, Under Hood Full Radiator Bug&Gravel Screen, Cummins Exhaust Brake, Agate Dash Cover, AutoMeter SportComp Exhaust Gas/Boost/Oil Temp, Passport 7500 Detector, Garmen GPS III+, B&W Turnover Ball Model 1394R, LineX Bed Liner over the rails, Westin Step bars LineX coated. E-Mail at res02cke@gte.net -Working on the rest of the goodies as I can afford it.
I will let everyone know what i find out from them, I believe that the sun will not be an issue as this is a pure high intensity LED/Florescent display system, however I will ask. So then it sound slike if I can get this thing up and running there are some takers. I am going to address the multi function unit as I would think it would cost more however getting the basic ones to our liking would be a great first step, i cannot see any reason why they cannot do this.
Yes it does have a turbo shutdown however not a "normal turbo shutdown" this one is really cool, it actually watches boost and based on how hard you push the Turbo it will vary the cooldown time and is fully adjustable.
Yes it does run off of signals from the ECM however the boost is from its own trasducer so that should not be a problem. If I can get one of these working I will get it in my truck and make sure that it works before I say everyone go buy it.
Ram-Taz
I have a factory Heads Up Display on my Grand Prix. It needs a special windshield for everything to work right, which is a couple hundred more than the standard one. I'm wondering if this unit will require a diff. windshield or if it won't be as clear?
2001 Quad Cab Dually, 6 speed ETH, SLT Plus, Isspro Pyro & 50lb Boost, Dual Fuel Pressure Guage, EZ Box, 275 injectors, Banks Power Pack, custom airbox, amsoil dual bypass, 4" DD exhaust, Horton fan, Ceramic clutch, Air Lift airbags.
'94 SLT 4x4 V-10, straight pipes and a K&N (can't find anything else :(
Good point, my friend has that Grand Prix GTP with the HUD and the windshield has some special coating above the HUD. Is this thing going to work without it?. Also, have them do the boost in PSI, not BAR
no if you notice there is what looks like a very lightly smoked color patch on the windshield it will attach with a adhesive backing what you refer to is a polarised screen for the reflection.
Mike ,count me in for one
please try to get them to offer an option as to what displays we can choose from.
thnkas
bob
Too cool! I really like the idea of being able to program the thing to show the info you want. Need to see Tach, EGT, boost, Speedo for sure. Would also be nice if you could have a second set of screen of other engine, trip, mileage etc info.
I'm definitely interested.
I like this idea also, a simple switch/button to toggle back and forth between different screens maybe. I'd be very interested.
Kurt Voss
********* 1999 2500 24VCTD AUTO 4x4 QC LB Laramie SLT, Luverne stainless steel nerf bars, 3 piece bug deflector, mopar mud flaps, Line-X bedliner, Blue Chip Fuel Management System (Premium), Psychotty Air, DD3's,TTPM, DD 4" exhaust, HX40, DTT VB/TC(91%) , Mag-Hytec transmission pan... YEEEEEHAAAA!!
I'm interested also, but will this break the void sticker on the ECM when you plug it in, or does it plug in somewhere else? Will it scroll through all the modes at the same time so you don't have to reach up to change the mode? Too many questions!
B I G O R A N G E AMBER-FIRE (BURNT ORANGE) / BRITE SILVER 2001(. 5), 2500, SLT, Q-CAB 4x4, SWB, AUTO, 3. 55, LSD, TOWING PACKAGE
ADD-ON'S: LINE-X, 1/4" STEEL LONGHORN HITCH COVER, WESTIN NERF BARS, YELLOW-TOP OPTIMAS
If it's 250usd, I am interested! Would need a TDR member to road test and review it first!
Mike, I think you have been trying to out search engine me. Too much time on your hands these days??
[This message has been edited by David_VT (edited 05-11-2001). ]
