Recently found rust starting in the following location. open the driver and passenger doors. from outside the door look down forward of the bottom door hinge. there is a space there that maybe filled with leaves ,mud etc. this material is wet and starts rusting showing up as bubbles in the paint outside.
Just discovered on mine on the right hand side. Needs to be cleaned out and some anti rust sprayed in there. #@$%!
