I've got an intake manifold coming and wondering if I should remove the "heater grid" what does this heat? From what I know it's a heat element for the air intake. Why would you need this?
I had a friend that took his out of his 05 two years ago, it started just fine @-3. So I never used mine all last winter,just to see how it would start up in the U. P. of Mi. when we was snowmobiling. It was -10 when I left , truck started just as always with out them! So I removed mine, I did find out that you can not remove the relay,as I did, had to put it back on. With out the relay it gives code # 541 low voltage to heater grid relay. It has been -4 and started like it was 30 out. I have never pluged the truck in! I did not like the heater grids coming on and makeing the lights go dim. IMO. that is hard on the alt. My guy that works on alt. (job) he did say that he thought it was hard on the chargeing system as well! But thats just my $. 02 worth!
The relay is on the right side battery, sorta under your inlet air line from your filter, I did not want to say too much about the inprovement,of air flow,but when I removed mine,that was when I put my afe intake on at the same time! made my truck smoke alot less! More air = less smoke! I could see that in the first five miles I drove.
There should one cable from the battery to the relay( solenoid) two little wires, too the relay & one large cable to the grid heater.
