not bully dog it is the bd power i have had problems with the one in canada
RJ- Mine has not set a code. Sac is pretty hot most the time, right?
Adam has had his on his 01. 5 for the last year and hasnt set any codes. He ran it in Tahoe this winter when it was 33F with out a problem. Took a little longer to start.
Cody- hey its not BD right:-laf, No im not a race only, but a daily driver. But air flow is the name of the game right? every little bit helps. If you have a intake and high flow filter, why choke it down at the heater grid.
BTW it took about 10 mins to swap so you could run it in the summer and put your HG back when it gets cold.
unless your running a straight up race truck without an intercooler, this is probably a waste of your money imho...
I've always let the grids run. . Why not? I never understood why everyone is against the "grid heaters" cuz they are part emissions.
You are not gaining anything by removing them permanently or unplugging them during the cold months. It's just going to get your stranded.
However, summer months 40 degrees+, yeah, they are more of a restriction then anything.
I'd rather have the motor start and run on all 6 cylinders then 1 or 2 for a while IMHO.
Go ahead, shoot a can or two of either once or twice a day in Alaskan temps all winter, lets see how long your motor lasts...
Tho, my work I can plug in. At home, I leave the truck plugged in. I may get a dozen cold-ish starts all winter.![]()
grids are for girls jk hahaha:-laf
i dont know what everyone is freakin out about, my truck starts and runs on all six at 10 deg and the 24 valve wouldnt start at all with a completely stock motor, the common rail will start at 25 below zero without ether so i dont know what you guys are talking about, if you have to start your common rail on ether you have engine issues, the grids on a common rail are more for emissions which i dont have to go through therefore i dont have grids, so to each his own grids are for girls jk hahaha:-laf
, I DONT KNOW WHAT TO TELL YOU, MY TRUCK ALONG WITH SEVERAL OTHERS IN MY AREA START YEAR LONG WITHOUT THE GRIDS AND NO ETHER SO TO EACH HIS OWN.....I'll bet you $$$ that you could not get a CR to start at 25 below with out a block heater or grid heater. Heck, I don't think you'll get a cold-soked (12+ hours not running) CR to even start at 10 degrees on the first crank.
They are not just for emissions.
