Heater motor surge
? for you all (South Bend Clutch install)
pop noise
Yesterday the heater motor surged twice at the same time, acted like a low voltage problem for a very short moment. I have not experienced the problem since this time. I have read on previous post that the A/C blower has been replaced a relatively low milage. . under warranty. . Interested in the early signs and symptoms of blower motor failures. . Sounds like the parts are cheap, but pretty labor intensive
2006 3rd gen 3500 4X4
if it was at startup, the intake grids are probably the cause [colder weather now]. . they draw some big amperage, and the lights will dim, the blower speed will slow, everything electrical will slow down as the voltage drops. .
if it is the grid heaters causing it, it is normal
