I have heavy gray smoke off the bottom and the turbo is slow to spool. Seams like I have to realy get my foot into it to make any power. Once boost is up seams to pull alright, not what it should though. Seams turbo is behind. Maybe a boost leak somewhere. I don't know. Boost seams to always stay low when cruising 7 lbs. I have a B-1 with a 10 plate. Star wheel ajusted up. Lots of temps. Does not like to lug in higher gears. Temps come up and boost is slow to climb till about 15 lbs and then takes off. By then temps are too hot.
Thanks
anothe thing, I noticed tonight at idle that the truck has a slight shake to it. Any chance that I'm having problems with one of my injectors?
Thanks
