First of all I would like to thank you for letting me join. Thank you!
First time posting here but I have a problem I have not been able to figure out. I have an 06 with the 5.9. I am getting the code 0148 fuel delivery error. I have replaced the lift pump as I was told by a local shop was the problem. That didn't fix it so I later got a code for pump regulator control so replaced that also. The shop said I had low pressure from the tank. The truck runs good until it reaches n.o.t. then it loses power smokes white/blue smoke and will stall out when slowing down to a stop. In order to get it to restart I have to turn off the key and then it will restart. I had a problem last winter with the injector harness and replaced that. At that time I had done a check on injectors and found one out of specs so I replaced that one injector. Everything seemed fine for a couple weeks then this problem started intermittently. Now it will happen whenever the truck gets warm. I am suspecting the injector has gone bad or may be leaking. Any thoughts that may help me out?
