hellwig anti sway bar mount question
Pac Brake
Gauge recommendations/ digital gauges
Hey, I stopped buy the local auto parts store to check the price of the rear Hellwig anti sway bar for my 01 and the book called for factory mounts where the shock attaches to the axle. My truck is a 01 ST, Has anyone else run into this? If so do you know the p/n or what it entails to install?
Thanks
David
Oo.
This might help.
On my 96 the brackets just bolted up to the plates on the bottom of the shock mounts. No holes to drill , and all the hardware was in the kit. Good product and great customer service.
Disclaimer ; I don't work for them:cool:
David,
I tried a Hellwig rear bar and took it back because the bracket holes did not line up. I also know folks with earlier model Rams had no trouble and it bolted right up :confused:
I would make sure you can return it if it's not correct for your truck.
