I made my annual trip to northern AZ from SoCal this past week...and upon returning pulling up the Ocotillo grade with the outside temperature hovering at 109 degrees...my engine cooling fan clutch would not engage! Coolant temp quickly ramped up to 245 degrees and gave me the EVIC "red thermometer" icon and chimed...so I slowed down and got it under control...very slowly without any fan spool up, unfortunately.
Last year at almost exactly the same date, I experienced the same problem...took my truck to the dealer (I have an extended warranty) and they replaced the ecm bird-brain with a "refurbished ecm" and told me they solved the problem. Evidently not...and now I have a refurbished ecm for my trouble. Other than this one trip every year, I don't tow anywhere else at these extreme temperatures...mostly tow in the fall/winter months...so it took a year to recreate the problem.
Can any of you TDR gurus tell me what is going on with this ecm-controlled fan clutch...and what is going wrong with mine...so I can tell my ignorant dealer service writer what needs to be done to solve my cooling problem before I ruin my truck.
I have the CD version of the repair manual...and I can't find anything useful in its contents to help me troubleshoot the problem myself. Worthless compared to my 1995 repair manual that was a printed manual. If the info is on this CD, I can't find it.
Anyway, I need to tow my trailer back to AZ again next week and will be returning about a week after that...and without a fix I'm going to have a rough time getting home without being a marker buoy on the road to other motorist.
Please help me if you can...and thank you for your time.
Kevin
Kevin
