So I changed my transmission fluid this morning on my 2007 5. 9 with 33,000 miles. Transmission and transfer case fluid change went smooth. Then I went to adjust the front band and did everything the factory service sheet(printed from an entry from this site). Backed the locking nut back 4 turns, then started to crank down on the adjustment screw with my torque wrench to 72 ft pds. Well the screw was getting tight so I pressed just a little more for break over and heard a pop. Well I thought the pop was the the torque wrench when I felt the tension screw had lost its tension and I was able to scew it in as far as flush so I just backed it out to where it was and tightened the lock nut. Now the truck has very poor shifting and I am scared s***less that I broke the band... . does anybody have any experience with this and can I fix it today or do I need to take it to the dealership. . ??Thanks guys
