Archived Help! '93 W250
Archived Injector help in Las Vegas
Archived Starter relay location
'93 W250. I just put on a new lift pump. Got it all primed up and she started with a little cough and sneeze but other than that she ran fine. I drove her down the highway for about 10 miles, and stopped to get fuel. Went to start back up and it wouldnt start, turned over but wouldnt fire off. Soundt to me like its losing prime, but how? Does it sound like im sucking air? BTW, today is the first time in about 7 months this truck has been started. Thanks for any help
Is your fuel shut off solenoid pulling up? If not push it up and tie it in place.
Have you tried priming it manually ( I believe you have a lever or button like the 2nd generations).
Try loosening the banjo bolt of the supply line to the fuel filter that should get air out of the it. You mite also have to crack the injector(s) to get air out ( if air is the problem).
