Help...Autometer EGT Z-series.
8.3l cummins
Un-usual hesitation
I am in the market for some gauges and have pretty much settled in on the Z-series by Autometer, but I'm alittle confused about the different models on the Autometer website. There are two different EGT gauges offered. Both are 0-1600F, but one comes with the probe and is a 'street series' and the other says it is a 'pro or comp series' and the probe is sold separately and uses a K-type thermocouple. Can anyone tell me the difference or better yet remember the part number from the gauge that you bought. (I have both #'s recorded from the website. )
Also what are the pros/cons to pre/post turbo prob site?
Tim
2001 Quad cab SLT, SB,4x4, Lt. Driftwood, Agate cloth, Auto. , loaded, camper & trailer group, snowplow prep. , Extang taneau, Bosch 275's.
Autometer probe #5249 is a street series probe. The pro or competition series is for
top fuel engines and are not needed for our Dodge. I got the Autometer #4344 which is
the Pryometer and #5249 probe (sold together)
from Geno's Garage for 120. 00. Works well and very reasonable in price.
Search the archives for "pre or post" turbo
probe install.
2000 QC 2500 4x4 LWB ETC/DEE, Anti-Spin, 3. 54, Trailer Tow, Camper Special, DD1's, PS boost module, PS high idle kit, PS steel idler pulley, Autometer boost and EGT gauges, Westin nerf bars, Rhino Liner
My Toy
1969 Toyota Land Cruiser FJ40
350 TBI, Turbo 400, ARB lockers front/rear, 4 wheel power disk brakes, 4. 88 ring/pinion, 3 speed transfer case, full roll cage, Warn 8274, MRT 36 bolt beadlocks with Super Swamper Boggers (16x35x15), Saginaw Power steering, custom bumpers/fenders/nerf bars/skid plate, GM tilt steering column, 6 point roll cage, RCI racing seats with 5 point harness. Loves to be pulled behind the Dodge and pass the powerjokes going up hills.
The #5244 is a heavier duty probe. Was told by Autometer twice to use this probe (emailed them twice). So I run that probe based on their advice. If ya compare the two the 5244 looks much beefier.
The "competition series" probe is faster reacting, but does so by having a thinner (or absent) protective metal cover over the probe tip itself. The "street series" probe provides more than enough reaction time for me, and costs quite a bit less.
I was surprised "just how fast" the street series probe reacts, despite it being the "slower" of the two versions.
Greg
Y2K Dodge Cummins QC 2500 SLT Laramie 4x4 Long Bed, 4. 10/Auto, Forest Green/Driftwood, 265x75R16 Michelin LTX, 6 speaker CD, Camper/Tow/Plow Packages, Westin Black Nerfs, Mopar bedliner, Ultra bright diamondplate toolbox, K&N Filtercharger, Autometer Ultralite EGT and Boost gauges in 2-gauge pillar w/tweeter, DD Stage II injectors, boost module, and boost elbow. Yee haw!
http://www.rints.com/hammond for photos!
You can use either probe in a Cummins. But its true, the street series all though advertised as being "Slower" responding, is really not slow at all. There is a difference in response, but the difference is small enough that depending on your application you could use it and save smoe extra $$. However, if your truck is highly BOMBED, it is probably worth the extra money as insurance with an engine that can produce highe EGT's very quickly.
I have the street probe and it is very fast. The EGT gauge will move right away after I get off the gas. To me this is an non issue.
My 2 cents. .
Charles
My Toy
Statebull,
I have the Z Series #2654. Got it through Summit Racing for $100. 99 plus shipping.
I had to wait however, it was on back order.
So I suggest you make sure the dealer has it in stock. I like it and it reacts fast enough for my purposes (see Sig. ). It included the probe. Good luck.
White 2001, 3500, Auto, 4:10,QC,2WD,LB, A-pillar mounted transmission and EGT gauges,34' DBL slide Cardinal 5er (12,600 GVWR)
