Help---bd short shift leak
Air filter system replacement - AFE or Scotty3?
how many quarts?
Did you put the BD spacer over the stock rubber isolator? That's how I did mine and it leaked too. A few have said by putting the aluminum spacer under the rubber one, and using a good sealant, you can get rid of the leak.
what big hammer said,
sealant (don't be to skimpy the stuff is cheap), on both sides of the aluminum spacer, place that on top of trans housing, and then the rubber spacer.
steve
Permatex #2 worked for me. You should use something that remains pliable. As already said spacer down first then the isolater metal side down with lots of goop on everything and you should be styling.
