So I have a A0382 Code that I can't get rid of and my old 2001 can't pass the newly required CA smog check. Easy Relay fix or removal that won't throw codes? I actually still have my heater not a spacer, should I try bypassing it?
The other problem is my Edge Comp, does anyone know if this shows up during a CA smog if off? For some reason if I unplug the comp I throw all kinds of boost codes that also fail my smog.
Help!!!!
Help!!!!
