help! filter prime
Rear end
Anyone using Baldwin PF7854 on 2000 and 2001 trucks Read!
highland:
Thanks. I have had my truck stop once unexpectantly. After about 30 seconds of running the starter it took off. I'm wondering if I don't have a transfer pump problem.
Originally posted by RobbyRam:
I had my fuel filter changed at 15K by Pro Fleet, a 'Big Rig' type quick lube place and they just unscrewed my cannister top, pulled out the old fuel filter and installed the new Baldwin filter and filled the cannister with diesel fuel, screwed the top back on and started the truck up and off I went. I have driven 16K since with no problems.
I am reading my current "Cummins Power Booster Quarterly" and it states the Baldwin PF7854 does not meet the specifications on 2000 and 2001 applications! Says it can short out the Water In Fuel sensor! The Baldwin is 2. 5mm longer and 1mm larger in diameter. Also the metal endplates are causing a problem.
Just thought I would point it out.
This information is in the Fall Edition of the Cummins Power Boosters Club Quarterly.
[This message has been edited by KatDiesel (edited 12-24-2000). ]
