Archived Help!! Friend broke down!!
Archived 99 cummins- Fuel in oil???
95 auto cummins,, tach goes to zero,transmission comes out of over drive,all the idiot lights come on in the dash and the charging stops charging. .
This is a friend thats stuck in Colorado,,If anyone has any ideas as to what may be the problem please pm me. . Thanks for your help!
I was thinking it might be the power control mudule???
Have them check the pcm connectors on the drivers side on the firewall. Somtimes the get dirty and wont have good connection. If they are dirty just use some contact clean and then coat them with dioelectric grease.
I would check all the connectors to make sure they are all nice and tight. .
Rick
If the engine speed sensor(crank sensor) gets flakey the pcm will shut down,and no pcm functions will operate. Check this first.
Bob
I am thinking crank sensor or wiring at the connector. I believe it is mounted near the harmonic balancer on a 12v and sometimes the wiring gets a little screwed up. There was another issue like this a while ago. You may be able to do a search and find it but look at the crank sensor first. If the engine does not know it is running by this sensor and the tach everything pretty much shuts down.
Dave
My started acting up so I took the connector apart and cleaned/greased it up and since then it hasnt given me a problem.
But I didnt stop there... I went ahead and cleaned/greased all the connectors just to make sure. .
Rick
Thanks for all your help I told my friend to try these things,,He says he drives for about 10 minutes then the truck stops charging and comes out of overdrive,low charge light comes on,and other dash lights. .
