I am in the process of tabbing my KDP. About ready to go back together and the instructions for front seal are lacking - or I am!
There is a plastic stepped cone in the seal. I assume this is to aid in getting the seal over the crankshaft snout without bending or pinching the teflon seal and to insure it seats properly to the shaft. The front seal will be installed in the cover prior to reinstalling the cover. If so "What do you do with the plastic stepped cone once cover is installed" Just pull it from the seal out the front with PLIERS???
Also there is another seal of some sort that is of a smaller diameter than the bore in the front cover for front seal. Again I assume this just pushes onto the crank snout after front seal and cover are installed to maybe keep out excessive debris/grit/grime to protect the actual front seal??
For those interested mine is a 94, 3500, 4x4, 5sp, Box Stock,
118 k miles. The dowel pin had not moved, all other bolts under cover were tight. No failure was imminent but feels good to know I will not have to worry about it now. I used a special tab supplied by board member REBEL. I expect it to add 7 HP, Lower my EGT's by at least 250 deg. , and increase mileage 3 mpg.
Any guideance / help appreciated in advance.
