HELP Just changed my oil in my 2006 2500 5. 9L, put the wrench on at 30 ft-lbs per the manufacturer of the plug and it let loose. The plunger is still there, so I plan on draining the oil with the drain tube and then SOMEHOW remove the brass plug. Any suggestions on how to do this (I am no mechanic)... also, in reading previous threads people had mentioned that there may be parts from the plug in the oil pan now. . is this possible because the plunger is still in tact? After this I am going right back to the stock plug, GENOS needs to increase the wall thickness on these plugs to take a wrench!
ANY HELP GREATLY APPRECIATED! THANKS!
Aric
Aric
