I got a 12 valve today and need some help with identification of some things. 1st, the fuel pump. It's got a giant p pump on it but the rear end of the pump is different than regular truck models. There is no star wheel like on the trucks and it is basically flat behind the AFC housing. The numbers on it are 908 in the corner of the tag and 56300 03284 in the middle of the tag and the tag on the rear of the pump has RQV400 1250PA964 23K on the top and the numbers on the bottom of the tag are barely legible and I can't read them until I get a chance to clean it some more. 2nd, Then engine family is SCE359D6DAAA and the engine number is 45183768. This thing melted #2 and #6 because the pump failed and started dumping fuel so this is how I ended up with it. The block looks good so if everthing works out I will be building this for my old flatbed. What can any of you tell me about it?
