HELP...Injector Install
Bad DEE trannies from vendor
4.10 Gears or not
I have installed new injectors and am ready to tighten down the injector retainers. How do I verify that the injectors are seated all the way down? Is there supposed to be a gap between the head and the retainer?
Thanks
Troy
2001, 2500 Black 4x4, Bank PowerPack, DTT T/Q and VB, K&N. Max Boost about 38lbs Pulling a 9000 Weekend Warrior full of dirt toys for the whole family.
If you can get the retainer on over the injector it is seated. Make shure the fuel inlet on the injector is properly oriented. Be sure to have an lbsin torque wrentch. yes there needs to be a space between the retainer and the outside retainer boss so that when it is torqued that much force is on the injector to keep it seated.
What inj's are you installing.
I hope you did not pull all the injectors at once. Best to do them one at a time. Not a big deal but it is nice on the first install to have the next one to compair.
2K, 2500, Quad, SB, 4x4, 3:54LSD, A/T, reese 15k 5th slider, EASLEY BULL BAR, WESTIN NERFS, TA's, 9000's, stealth DD2's, Bully Dog Boost & elbow, ISSPRO pyro, boost & transmission, Turbo Lifesaver, JARDINE 4", DTT VB,TC,TC SAVER and AUX COOLER, PAC BRAKE, MAG HYTECH TP& DC, AFE filter onboard. Taylor Wing and Gear Vendors on order
pullee #1 26' Arctic Fox 5th
#2 22' car hauler w/ 76 Pinto 392cid or 68 Cyclone GT Cobra Jet FB
NRA-LIFE, VFW-LIFE, SoCSA-LIFE, SASS
[This message has been edited by JNutter (edited 03-10-2001). ]
Whew... ..... Thanks. I finally got everything installed and took it out for a test drive. WOW is all I can say. Those injectors made all the differance in the world. Can't wait to tow. The injectors are DD1's.
Thanks again...
Troy
