JRunner asks: ... ... ...
Moved here for member's help by: ... pb
"... ... . I need some expert advice. I am having trouble with my 91 dodge, it has been getting harder and harder to start over past couple of weeks. finally died and will not start now,luckily it died at my house so did not need to get it towed. Over the last couple of days i have replaced the fuel filter,fuel lift pump,and added 5 gallons of gas just in case gauge is not working. still would not fire up. After reading some articles on the tdr i tried cracking the injectors loose and started cranking it over, after about 5 seconds it started to shoot fuel out, so i tightened them all back up and tried it again, started right up, let it runfor about ten minutes and shut it off waited about 5 minutes and would not start again. went through whole process again and same thing happened, started right up ran fine shut it off for a little while and then it would not start again. That is where i am right now. Any advice or ideas would be greatly apreciated. thank you..... "
Geezzzz... . I hope you just "mistyped" with you said you added 5 gallons of gas
pb...
pb...
