Joe:
See insertions to your comments/questions. .
>>>Yes, I moved my plate all the way forward after the 3K install.
Yes, I had great boost until I messed with the 3K, moving the Banks plate forward and turning the AFC wheel towards the engine about 25-30 clicks.
Put the plate back in the middle. . ck. where the lever contacts
You may have to change one thing at the time to isolate which mod caused the issue.
>>Not sure what your refering to about an o-ring on the AFC. I replaced the line with some new 1/4" tubing, new ferrules and nuts.
Take the AFC line and try and blow thru it, with one end covered. . its probably alright. Once in a while the sealing "o-ring" (slide the nut back, it acts like a ferrule and a seal) falls off. If it checks out reinstall it and the oem fittings.
Its also possible that the diaphram was torn inside the afc housing, but this is a long shot...
>>Do you have to run the fitting on the AFC that has the orfice?>
Yes, I think I confused things, I thought you had a 175 hp (94-95) not a 1996-1998 215 hp engine. Your application has rubber and steel tubing providing the wastegate with boost as it needs to "blow off" as necessary. . The orifice restricts this from happening until later. Remove the tin cover over the valve covers as necessary for a better view. I remove the "barbed fitting" and put the orfice there. . if its indexed right the rubber boost line will slide right onto it and then snug up the clamp (after afc is re-installed on the engine). Put some thread sealer or small amount of teflon tape on the threads of the fitting.
Disconnect the rubber line from the wastegate and the afc, block wastegate end and blow thru the metal/rubber tubing combo, do you have a split in the metal or rubber lines somewhere. I've seen them chafe on a valve cover and leak (steel tubing). If it ck's out, slide some rubber tubing over the metal line to protect it from touching a valve cover.
>>My new tubing kept pinching cuz of the tight 180 turn it must make, so I just replaced that fitting with a 90, tefloned the threads and it's good.
Reinstall the oem afc line if it ck's out.
>>No, I did not blow a boost boot anywhere, I have checked every clamp and boot. Good and tight.
Are the intake manifold bolts torq'd to 18 ft lbs. ? Are the base gaskets torn or seated properly. .
>>How is your star wheel oriented?? If I am looking at it from the top from the driver side, then the wheel turns toward the passenger side and the driver side. I clicked it 25-30 times toward the engine and passenger side. I have been told that is the correct way to turn it for a richer mixture.
You correct in your adjustment of the starwheel, my illustration was from the perspective of how close the starwheel is the radiator end of the afc vs the firewall end, after your adjustment. If you spin the wheel towards the engine enough the starwheel will move towards the radiator as viewed thru the inspection plug.
>>I doubt my fuel pressure has changed and why it could change, haven't checked it thought, I don't have the ability to do that.
Could you have sucked some trash into a screen or plugged a fuel filter? The banjo fitting on the fuel water seperator/filter housing closest to the injection pump has a plug on the top of it. A 10mm socket will fit this. TST sells a metric adapter that threads in so a pressure gauge can be attached. The threads are m6*1. 0 by about 12-mm long? S/b 20 psi at idle and 30+ at rated rpm (2500 rpm or higher).
Poor, low fuel psi, means fuel restriction from a collapsed line, dirty, clogged filter or screens, stuck overflow valve (open position) allowing the fuel to return to the tank, rather than supply the pump as necessary. Transfer lift pump that's not up to snuff etc.
Also ck. the air filtration for no clogs, restrictions. etc. .
Most diesel literature always states for low power/ boost to check for proper fueling and air entry/flow. Either doesn't allow the engine to breath, or to have sufficent fuel to run properly. I follow this and a through ck. of innercooler plumbing throughly with such concern.
I have a homemade boost tester to check for any leaks in the innercooler piping etc.
Okay enough commentary but a little history/backgroung may help your troubleshooting in the future. One last war story. . I installed some gov. springs about a year ago for a customer only to have them call a tank or so later and ask why the truck ran so poorly after running so well. Turned out a fuel filter change fixed the problem. We had verified fuel psi at the time of the gov. spring install.
Maybe Mr. Murphy has taken up residence on the left coast, come to think of it he's stayed outta my way the last several days!
>>Please respond to these answers, thanks
Joe>>
Hopefully, this has helped. Andy
