help limp mode
Running problems. Need help
Transfer Case making noise
I am 200 miles away from home and check eng light came on . read codes at auto zone and p2149 cirit falure on 456 cyl.
I just had a injector replaced 5000 miles ago it was no. 6
Can I unhook battery and get it to go out of limp mode?
Thanks for any help on this,, Larry
Check the wiring plug that plugs into the valvecover. You might have a pinched valve cover gasket that contains the wiring for the injectors. KEEP US POSTED! Where are you broke down at?
limp mode
I am in Johnson City at my daughters. I took it to the dealer yesterday ( most likely a big mistake)
I am thinking it is the 6 injector that was just installed 5000 miles ago.
It has 12000 mile warranty on it.
So we will see.
