HELP!-Need instructions for Painless Wiring 7 circuit fuse block.
Oil Cooler Protection
I Put The U.S. Flag Sticker On Truck.
I got everything out to install the fuse block, my Turbo Temp Monitor and clean up the wiring a little and I can't find the instructions/diagram.
Can someone please e-mail it to me?
TIA!!!
Eric
Painless Wiring
From memory,
Run heavy red wire through firewall connect to solenoid(?) and on to positive terminal. Small diameter pink wire runs to fuse panel on left hand side of dash, I'll check which terminal I tapped and post later.
I mounted my PW block on a bracket I attached to somewhere close to the top of the brake pedal.
More later,
Glenn
OK, Thanks, I was trying to figure which wire was the "trigger" for the switched circuits. I'll get out the voltmeter and go from there.
Thanks again!
Well, it's installed...
What a POS! I got the "outside mount" version.
The supplied screws are too short. Hardware store not open. Found some on hand AFTER I drilled the holes. Ended up redrilling a hole because they didn't line up after increasing screw size. :mad: :mad:
Then I noticed the ground wire ring didn't/couldn't line up with the mounting screw hole. It was located too far above the surface it is supposed to be flat against. It was also not lined up with with the hole and the wire is held in place by the weatherproofing cement used to seal up the back side of the blocks. :mad: :mad:
So by the time I get all ths minor crap sorted out and the block screwed down (took WAY longer than it should have) it starts to rain and I have to stop. :mad: :mad:
