Details here: TDR Privileges
I assume you bled the fuel supply line first... bumped the starter to induce the lift pump to purge the air from the line.
Since you started with a new (dry) VP44 you should then:
Crank engine for 30 seconds at a time to allow air trapped in the injection pump to vent out the drain manifold;
Clean around injector fittings where they join injector connector tubes; Bleed air by loosening high-pressure fuel line fittings at cylinders number 3,4 and 5;
Continue bleeding injectors until engine runs smoothly. It may take a few minutes for engine to run smooth;
Tighten fuel lines at injectors to 28 ft. lbs.
got it going. must have been alot of air. 2001. 105k k miles on 1st vp with fass system. fass has been in there for 5yrs with 0 issues. thanks. no more vp44 blues. b
