2nd Gen Non-Engine/Transmission Help No Heat!!
Engine/Transmission (1994 - 1998) Stack
2nd Gen Non-Engine/Transmission A/C quit working. Any ideas?
Had a little problem last night while plowing snow. The truck acted like it shorted out, lights flickered for a second then airbag light in dash came on, heater wouldn't blow any heat, and power windows wouldn't work. Don't know if they are all related but seems to be cause they all happened at the same time. Checked all the fuses and everything is fine in fuse box inside cab. It was dark so thats as far as I got. Anybody have any ideas? Any help would be appreciated
This is on a 94 12v
You might want to move this over to the 3rd gen forums.
My '99 also has a fuse box under the hood on the left fender, but I don't have a clue what the 3g trucks have.
Is your alt charging? Sounds like the alt may have bit it. Check the big 100a fuse in the main fuse box between the drivers battery and the brake booster. Possibly lost something in there...
Other than that, mebe a pinched wire somewhere, if ya rammed that snow too hard, mebe it moved something. . hmm
good luck
-j
