Has anyone had trouble loosening the nut on the eccentric bolt (caster adjustment) on the lower control arm? I took my truck in for an alignment the other day, and the tech sheared off one bolt trying to get the nut loose. He couldn't get the other one loose, and didn't want to twist it off as well. I had to wait for new eccentric bolts and washers to come from the dealer. Didn't want to pay another hour of shop labor for the alignment guys to simply install the new bolts before they did the alignment, so I figured I'd change out the bolt myself at home.
Well, that nut is on there and it aint coming off! I don't have access to a torch, but I can get hold of a heat gun. Would that work to heat cycle the nut? I have soaked it in PBlaster, put a wrench on it and beat the wrench with a 5 lb sledgehammer. Any other suggestions? I can't get enough clearance to get a long cheater bar over my long breaker bar and turn it.
I did a search and couldn't beleive it when I found a thread talking about people having trouble with these bolts working loose! Any suggestions would be appreciated.
CTD12V
CTD12V
