Suddenly, in the last few days, my oil pressure gauge drops to 0 and the check engine light comes on and chime rings while sitting at idle. This happens only after the engine is fully warm.
I did a search here and I'm aware of the TSB that reflashes the PCM to change the parameters of the gauge so that it fools it to thinking it is reading a bit higher pressure. But I don't really want to fix the symptoms.
I also found a few owners had success by changing the sender, but several said it didn't help or last long.
I intend to change the oil & filter (oil level is fine, BTW) since its due, and change the sender to see if that will fix it.
However, my question is, has anyone who has experienced this found another reason for it and a solution that actually fixed it? My only other thought is the oil pressure relieve valve, which may be allowing oil to get past. I believe that is found in the oil heat exchanger cover (the assembly on the side of the engine where the filter screws in to).
TIA,
-Jay
TIA,
-Jay
